Updated Mar 2025
vTaskSetTimeOutState()
[Task Utilities]
task.h
1void vTaskSetTimeOutState( TimeOut_t * const pxTimeOut );
If a task enters and exits the Blocked state more than once while it is waiting for the event to occur then the timeout used each time the task enters the Blocked state must be adjusted to ensure the total of all the time spent in the Blocked state does not exceed the originally specified timeout period.
xTaskCheckForTimeOut()
performs the adjustment, taking into account occasional occurrences such as tick count overflows, which would otherwise make a manual adjustment prone to error.
is used with
is called to set the initial condition, after which
can be called to check for a timeout condition, and adjust the remaining block time if a timeout has not occurred.
  • pxTimeOut
    A pointer to a structure that will be initialized to hold information necessary to determine if a timeout has occurred.
An example is provided on the xTaskCheckForTimeOut() documentation page.
