Updated Mar 2025
X.509 Certificates
When communicating securely across the internet, the client (IoT device) and the server must provide
proof of their identity prior to establishing a mutually authenticated TLS
connection. In a public key infrastructure, digital (or identity) certificates
are exchanged to verify each entity's identity. The X.509 certificate
is the most common digital certificate format and is widely used across the internet and in IoT use cases.
The X.509 certificate is exchanged during
the TLS handshake process
making it a critical piece of establishing a TLS connection. In IoT use cases, data transfer over communication
protocols such as HTTPS or MQTT should occur only after a TLS connection has
been established.
In PKI, a signature’s authenticity is established through a key pair: a public key and a private key. Public keys are disseminated widely, while private keys are known only to the owner; this is done to maintain security across the system. When data is signed or encrypted with a private key, any recipient of the data can authenticate and/or decrypt the data using the matching public key. Data encrypted using a public key can only be decrypted by the holder of the private key.
Once a key pair has been generated, a client will apply to a certificate authority for an X.509 certificate,
using a certificate signing request (CSR). The X.509 certificate is either signed by a
CA (certificate authority) or is self-signed. In most
use cases, the X.509 certificate is only self-signed when it is
the certificate of the root CA
. In IoT use cases, it is
more common (and better practice!) for an intermediate CA (instead of the root CA) to sign each end-entity’s
certificate. This prevents the risk of exposing the root certificate. Using intermediate certificates creates
a chain of trust
that can be traced from the root CA to each
end-entity.
Additional details can be found here: X.509 RFC5280.
