FreeRTOS for AWS IoT
FreeRTOS for AWS libraries implement clients for AWS IoT specific value add cloud services, including over the air updates (OTA). These libraries are suitable for building smart microcontroller-based devices that connect to the AWS IoT cloud. Like the FreeRTOS core libraries, they have no dependencies on anything other than the standard C library, so are not dependent on the FreeRTOS RTOS kernel.
See all
library categories.
Libraries
AWS IoT OTA
Source code is now available in the
AWS IoT Over-the-air Update github repository.
Learn More
AWS IoT Device Shadow
AWS IoT Device Shadow github repository.
Learn More
AWS IoT Jobs
AWS IoT Jobs github repository.
Learn More
AWS IoT Device Defender
Source code is now available as an independent repository in the
AWS IoT Device Defender github repository.
Learn More
AWS IoT Fleet Provisioning
AWS IoT Fleet Provisioning github repository.
Learn More
AWS Signature Version 4
Generate a signature and authorization header that complies with the AWS Signature Version 4 signing process.
AWS Signature Version 4 github repository.
Learn More
AWS IoT Core MQTT File Streams Embedded C
This library provides functionality to initialize the file streams downloader, create the request for file blocks and decode the received file blocks.
Source code is now available as an independent repository in the AWS IoT Core MQTT File Streams Embedded C github repository.
Learn More
Reference Integrations
AWS Quick Connect
Quick Connect demos make it simple to setup and connect a partner provided, FreeRTOS qualified board to AWS IoT, all in the space of a few minutes. These demos can be used for non-production applications to explore the IoT space.
For more information, refer to
AWS Quick Connect Demos page.
Featured FreeRTOS IoT Integrations
Featured FreeRTOS IoT integrations are pre-configured projects that demonstrate best practices to make IoT device software more secure and robust. These integrations are designed for improved security using a combination of FreeRTOS software and a partner-provided board with hardware security features.
For more information, refer to the
Featured FreeRTOS IoT Integrations page.
